Discuss Grout Joint Regulations in the Australia Tiling Forum area at TilersForums.com.
AMC
148
Dublin
Lads can anyone help me out here , I'm on a job and the lady in the house is sayin my grout joints are too wide , the tile is a porcelain wood effect , 900 x 25 and the grout joint I used is 2mm , it's on the walls and floor , the tile does have a slight bevel on the back which does make the grout joint a little wider , but I've told her 2mm is the minimum to allow for movement , many thanks
Sean Kelly
1,068
Ruislip
I would have tiled it at 3mm. It sometimes says the minimum joint width on the box. The only thing you can do is butt joint them, get paid and then run!!! Too many people are coming back from their hols and wanting large tiles & thin grout lines because that's what they have seen in their hotel. Not realizing that the substrate is concrete and the floors tiles have been diamond polished.
Dave
Staff member
Subscribed
389,925
1,000,000
Co.Durham
If its on both the wall and floor , then i would have gone 2mm as well ...
Reply to Grout Joint Regulations in the Australia Tiling Forum area at TilersForums.com
gamer1
Available - Porcelanosa Hampton Beige Floor Tile 22cm x 90cm (13 Boxes - 15.444 M2) Porcelanosa...
I plan to lay a circa 8m x 4m patio using a concrete slab and fixing with tile adhesive. The...
6K
Fired Earth recommend using a 3mm grout thickness on their 200x100mm tiles when fixed onto...
Steve the tiler
AMC
Dublin
    Votes: 5 4.6%
    Votes: 8 7.3%
    Votes: 6 5.5%
    Votes: 30 27.5%
    Votes: 14 12.8%
    Votes: 28 25.7%
    Votes: 3 2.8%
    Votes: 2 1.8%
    Votes: 19 17.4%
    Votes: 18 16.5%
    Votes: 13 11.9%
    Votes: 5 4.6%
    Votes: 3 2.8%
    Votes: 1 0.9%
