Discuss grout or silicon in the corners? in the UK Tiling Forum area at TilersForums.com.
U
user123
On plastered/rigid walls I always grout the edges. Looks so much neater having tight cuts and a clean uniform grout line down the corners than a dirty bead of Silicon. 10x the finish imo.
But,Wingn, there is no such thing as a rigid wall, houses move all the time. A clean sharp Silicon line really finishes things off nicely.
thevinnyofoz
I asked this very same question to atime served tiler today and he said it's up to the tiler to make a decision as it doesn't matter ! I think it does as everyone leaves a gap around the floor to allow for expansion and fill with Silicon why on earth would this very science not be applied to the walls ? after all as a tiler you are responsible for preparing the substrate and maximising the life of the new install.
Aston
your right vinny
and your also right about it/expansion being a science rather than an opinion so that means its been proven. i can see where he's coming from about it looking more aesthetically pleasing on the eye but expansion needs remedies or theres every chance the tile installation will fail and so will you reputation mate.
just because someone tells you they are time served, dont believe all you hear?. they may have spent 4 years doing the same kind of tiling day in day out whereas on here the information is vast and backed up by some very creditable tilers and technical depts. if your getting 8/10 on here singing from the same sheet, then you know you are on the right lines...
Reply to grout or silicon in the corners? in the UK Tiling Forum area at TilersForums.com
Been advised to move this post to the uk forum, didn’t realise it was in the USA forum Would...
Hi any advice on what would go with what. I've layed off white tiles on floor with grey...
Hi, Need to choose a grout for the above. For the black floor tiles 300x600 am thinking either...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
