detiling
Hello everyone, looking for a bit advice on the best way to remove grout. I have used the bosch pmf 180 in the past but find it a bit time consuming and the blades dont seem to last very long. Am i better using an angle grinder? if so what kind of blade should i use, will the one from my wet cutter be ok to use? Its a 115mm blade.
