Peter L
Hi All,
I desperately need help!
We have just had a walk-in shower tiled with 200x200mm satin finish Johnson's Prismatic tiles, and professionally grouted with Kerakoll Fugabella Eco Porcelana 0-5 white grout. To our horror, the grout and tile edges discolour within 3 minutes of showering (presumably due to water ingress), and by a couple of minutes later the discolouration has spread right across many of the tiles. It looks awful, and presumably isn't doing the tiles or sub-wall any good whatsoever.
I see that the grout packaging calls it water-repellant (not waterproof); is this the issue? Topps have suggested using a sealer, but I need to know if this is the correct advice, whether it will also soak into the tiles and leave staining forever, whether this is just a 'sticking plaster' solution, etc.
Worried that I'l need to remove ALL the grout and start again. Any advice will be much appreciated.
Thanks...
Thanks...
