Discuss Guess the SR No. in the Canada Tile Advice area at TilersForums.com.
Lol
on the left in the middle of the floor is a piece of 6mm marmox , to a 3mm packer on the left , on the right of that pic is 4 x 6mm + a 3mm shim.
the room is about 18m² and ( unfortunately for me ) runs from nothing top left corner to 45mm lower in the bottom left corner , Diagonally , so I'm stuffed basically given that it's the large stone stuff random brickbond effectively.
Levelflex o plenty needed on this one.
Diggy :)
Ajax123
1,213
Lincolnshire
SR class doesn't work like that. Surface regularity is measured over a 2m length. You place a 2m straight edge directly on the screed under its own weight. You then measure the deviation from the straight edge. Flatness/levelness and surface regularity are different things. That screed may be reasonably regular but not flat/level. Deviation of no more than 3mm is sr1, 5mm sr2 and 10mm is sr3
That said it does look a bit rubbish. :)
Reply to Guess the SR No. in the Canada Tile Advice area at TilersForums.com
I'm searching for 42 pieces of 12" x 12" Verde Alpi marble tiles. Preferably honed. 12" x 24"...
E
Wagos In Aus? To my fellow Australian or Kiwi Sparks is there any stipulation on using Wagos...
Electrical News
E
TilersForums.com has been online since 2006 and we've had many designs, even three forum...
Man gets fined for traveling from Sheffield to Stoke to buy tile adhesive. Note that you can...
I received an email about BAL External tile adhesive and grout this morning and thought I'd post...
5K
Gloucestershire
Guess the SR No.
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
