Discuss Guys ive solved the problem of bad calibration in the Canada Tile Advice area at TilersForums.com.
Balloo
598
Belfast
You can take a look at this format i came up with a while back, ive had numerous calls from tile shops as word has got about that this has actually worked for bad calibration in tile, most common i think in Spanish products,.
Try for yourself and see what you think, i now tile everything this way to eliminate any problems. Some of you may have came up with this already. If not id like a badge for being so great :gradcap:
Balloo
598
Belfast
I completely missing the point as to why this works in any way shape or form. Also are you talking about irregular shaped tiles rather than square tiles which may have a difference in size between tile to tile
irregularity in a tile jig is very common it can be small are large depending on manufacturer and QC, it throws of the true square of the material it can be counteracted by setting the tile in the pattern i posted that the good Lord himself sent me in a vision for the tile community to benefit from .
Try it out for yourself
Dumbo
So you are talking about tiles being out of square rather than being sizey .
Reply to Guys ive solved the problem of bad calibration in the Canada Tile Advice area at TilersForums.com
Hi everyone, I really need some pro advice as I have just had a bathroom fitted and the tiling...
Deleted member 53945
Im going to be tiling my shower room walls and floor with some large format tiles as per the...
Balloo
Belfast
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
