Discuss Gyvlon/Anhydrite in the UK Tiling Forum area at TilersForums.com.
Robb o
If your not sure just get a sharp wood chiesel if its really hard to scrape into I would say its more than likely to be SLC if you can scrape the surface easily (example Plaster work) its Gyvlon.
This is not exact science and it helps if you've worked these screeds before as experience will always count.
I think that all trades will be working more and more with these over the next 10 years or so,especialy on commercial builds where block and beam floors are standard
Robb o
@Rookery
Sounds about right mate
The problem is if its not temped out properly air locks form causing failure and try to temp out to late and lumps and bumps form,supposed to be self level, quick set so you can walk on it in a day so great for site work.
Got talking to on of the screeders on a job and he was off to Dubia they always use Gyvlon because of the high day time tempretures,sand cement would dry out too quick and crack.
He reckoned he was going to make a fortune TAX FREE this was a couple of years ago.
Ajax123
1,213
Lincolnshire
@Rookery
I think he will be sadly disappointed going to Dubai to lay anhydrite screeds due to the high temperatures...... They should not be installed at above 30 degrees c but hey ho. Also they are not supposed to be self levelling and are not sold by manufacturers as such also air locks do not form and cause failures and lumps and bumps only form if he screed starts to set before its finished ..... This gives a working window of some four hours. You must have come across some pretty poor screeders..... Oh and by he way anhydrite screeds are not temped or tamped they are dappled.....
Reply to Gyvlon/Anhydrite in the UK Tiling Forum area at TilersForums.com
I've just had the whole ground floor of a house we are working on levelled with a pump in liquid...
Bishbbashbosh
Hi guys technical question hoping maybe you have an answer as I have never came across this...
Heeelp!!! I've seen some old posts about this but nothing recently. I have 120sqm travertine...
Gyvlon/Anhydrite
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
