Stef
Looked at a job yesterday,
They have pumped in a Gyvlon screed over wet UFH.
I have read a lot about these screeds but just want to run over a few things.
Tiling won't be starting till August/September or if the screed drys out quicker.
Heating is getting commissioned in just over a weeks time, screed was laid 5 days ago.
They want to force dry the screed to reduce laying time for tiling. 80mm screed.
Is it just normal procedure with heating turned on low, 15degrees, then turned up in increments over the next few days?
To remove Laitence, what is best way to go about this, floor scraper?
To sand the screed, what is the best way again, Belt sander? Orbital? Or a sanding pole with pads?
What is the most suitable adhesive & primer to use? Needs to be stocked in CTD or can be ordered in through them or suppose direct to me.
Also upstairs they are fitting Brio 23 over wet UFH.
Can this be tiled directly or does it have to be over boarded?
Thanks..
Thanks..
