Discuss Hall flooring in the British & UK Tiling Forum area at TilersForums.com.
c&J
I have 400 x 400 tiles to lay in my hall which approx 20 sq meters. I'm using a porcelin tile and the the T&G flooring is in good condition with joists at 400 centres. What thickness ply can I use as a minimum to avoid large steps and what adehisve is best used. I plan to use a tiler, but want to be sure I get sound advice.
C.
Daveyboy
C.
If the T&G is greater than 18mm thick, I would overboard with 12mm ply and use a cement basid rapid set flexi adhesive..if the T&G is under 18mm thick, I would be tempted to lift the T&G and replace it with 18mm ply...
Reply to Hall flooring in the British & UK Tiling Forum area at TilersForums.com
Hi all, I want to tile over a completely new floor. New floor joists have been installed with...
I’m tiling a ground floor of a house approx 120m through a ground floor with 5 doorways in the...
Hall flooring
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
