Guest viewing is limited
Tiling Tool Suppliers
Discuss Hand Held Cutters in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com.
DHTiling
Makita Power Saw (110v only)
http://www.**************/acatalog/makita-4101RH-220.jpg
Wet cutting hand held power saw from Makita (can be used dry with suitable blade)
  • Water fed to both sides of blade
As every day goes by, tiles seem to be getting even bigger this can be a big problem when it comes to wet cutting. The traditional machines become so heavy and expensive they are not viable. With the use of a straight edge clamped on the tile/slab accurate cuts can easily be achieved.
Accurate free hand cuts can also easily be achived
Highly suited to grout raking by reducing the depth of cut
  • Electrical earth leakage breaker
  • Blade Diameter: 125mm - Bore: 20 mm
  • (we include ring to make standard 22.2mm blades fit)
  • Depth of Cut @ 90°: 40mm
  • Depth of Cut @ 45°: 26mm
  • No Load Speed: 12,000rpm
  • Input wattage: 860w
  • Net Weight: 2.9kg
  • 110v only (because of water)
  • 5 M water feed tube, rubber tap fitting
Included - Continuous rim blade rated for concrete - suitable some stone, travertine and marble. However we recommend a suitable tile blade is purchased separately
Blade Here
Price: £255.30 £293.60 Including VAT
Reply to Hand Held Cutters in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com
HI FOLKS. LOOKING TO EXPAND ON MY TILING TOOLS AND INVEST IN A WET TILE CUTTER. WITH SO MANY...
Hi, Need to choose a grout for the above. For the black floor tiles 300x600 am thinking either...
Hi all, I’m after a new hand held wet & dry saw cos my dewalts had it, and been looking at the...
Popular Tile Cutter Threads
Hand Held Cutters
    Votes: 5 5.8%
    Votes: 6 7.0%
    Votes: 5 5.8%
    Votes: 22 25.6%
    Votes: 13 15.1%
    Votes: 26 30.2%
    Votes: 3 3.5%
    Votes: 2 2.3%
    Votes: 18 20.9%
    Votes: 14 16.3%
    Votes: 6 7.0%
    Votes: 5 5.8%
    Votes: 3 3.5%
