Discuss Hardi backer or ditra on wooden floor???? in the UK Tiling Forum area at TilersForums.com.
Ren+
If this has been asked before I apologise, maybe someone can point me to a thread that covers this. I see many posts where tilers mention that, on wood, they don't tile without putting ditra down first and other posts mention just backer board or ply/backerboard. The question is when is it best to use ditra and when to use backer on wooden floors. Thx in advance to all input.
Ren+
Thanks for your input guys. To answer your questions ... I'm trying to get the best fail proof system for doing wood floors in general, so I can't say to you that the current floor situation is "x". I hear what you are saying, there are variables that will affect the choice of materials to use. Sir Ramic, IMHO, I'd agree with you that ditra would not help with bouncy floors, but then I'd say nor would backer board. Therefor I'm still not clear where and if ditra would be better than backer and vice-a-versa. Basically what I'm trying to confirm is when to use ditra, backer or both. What I do realise is that you should stabilise the subfloor before applying either. I would still appreciate your further input guys.
Dan
Admin
Staff member
5,096
1,323
Staffordshire, UK
I'd strengthen the floor now, before the ditra and / or backerboards.
Then if anything, use a backerboard then.
How big of an area is the floor? I'd perhaps not bother with ditra on a smallish floor if you've strengthened it and used backerboard too. If it's a large floor, then as Sir Ramic says, the lateral movement will be secured by using something like ditra or dural.
Reply to Hardi backer or ditra on wooden floor???? in the UK Tiling Forum area at TilersForums.com
I'm about to tile my kitchen with 600mm x 600mm porcelain tiles. I am tiling onto a subfloor...
Hi, Would you use Durabase matting over Hardie 6mm floor? Im not 100% happy with the ply floor...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
