Guest viewing is limited
Discuss Hardibacker Floor Preparation in the Australia Tiling Forum area at TilersForums.com.
ajc
can I just get a general consensus/hands up on here please:
Does everyone fix hardibacker down with adhesive as well as screws, or does anyone just use screws?
I've always used the adhesive as per manufacturers instructions but speaking to a few traders at the local topps tiles recently, all three others said they didn't bother with the addy? And the staff say you don't need to either (I know not to listen to them too much, but they say that's what their rep says ?!?!)
Oh, this is for a floorboard floor.
J Sid
Reassuring to hear, thanks....will continue to do it without feeling I'm wasting my time over-doing things!
How about no more ply......I've never actually used it, but just looked at their website and they just stick it down with a tube glue and only 8 screws.......is that right?
Personally I've had bad experiences with no more ply, so avoid it.
There glue tubes used to be pricey.
John Benton
1,138
Leeds
It is correct, I used to use it but found it far too brittle
John Benton
1,138
Leeds
The MegaStrength glue I use for all sorts of different stuff. Will stick almost anything as long as one surface is porous
White Room
You'll find that you will use more glue than they say.
Chalker
1,058
Tadcaster
Replaced a bathroom floor a couple of years ago. It had raised up in the centre of the room by about 10mm. Cracked every tile in a straight line.
Customer said it was laid onto no more ply. It was! When I took it up it was screwed only ( plenty of them) but screwed only!,!
Reply to Hardibacker Floor Preparation in the Australia Tiling Forum area at TilersForums.com
gamer1
Hi guys, I'm new to tiling and looking for some advice. I'm practical and usually pretty good...
Hi, I recently purchased my first property and the existing kitchen floor porcelain tiles were...
benchwarmer
    Votes: 7 5.2%
    Votes: 13 9.6%
    Votes: 8 5.9%
    Votes: 39 28.9%
    Votes: 16 11.9%
    Votes: 33 24.4%
    Votes: 3 2.2%
    Votes: 2 1.5%
    Votes: 20 14.8%
    Votes: 18 13.3%
    Votes: 15 11.1%
    Votes: 7 5.2%
    Votes: 3 2.2%
    Votes: 3 2.2%
