Discuss Hardie backer on top of shower tray in the Tanking and Wetrooms area at TilersForums.com.
Harrand
Kent
hi guys after some help
Am in the process of re doing ensuit. Have ripped out shower and base and want to know does the hardie backer go behind or on top of stone resin square tray? 3 walls are to be tiled and don’t think with the hardie backer installed all the way to the floor the tray will fit.
The tray that came out had the four little sides round the edge so was a little larger than the flat sided tray I have found!
Any advice is much appreciated
Harrand
Kent
Hi thanks for reply the old tray had 4 upstand/ lips round the edge where as the new one I have ordered does not, it’s flat top.
The original tray worked out about 773mm because of the upstands that were sunk in wall. In which they put harder backer on top of the lip.
I believe the space I have between the metal studs on the right and wood Battons on left plus 24mm of Hardie backer to the floor will not fit the new shower tray by about 10mm. hence reason for asking if Hardie backer can go on top!
I am minded to find a tray with the upstands and fit like for like if the best option!
Thanks again
Reply to Hardie backer on top of shower tray in the Tanking and Wetrooms area at TilersForums.com
  • Sticky
I am doing a shower tile installation on mold-resistant drywall and I am waterproofing with...
Wetroom leaked. Former and first course of wall tiles removed. WBP ply on joists (shower tray...
Kent
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
