Hi I am new to this forum and it’s a godsend for information and tips however there is one thing I cannot seem to find clarity on. I am tiling my bathroom floor small area 1.5x1.5m which is t&g floorboards very solid and screwed down no deflection. I am overlaying with 6mm Hardiebacker glued with Keraquick s1 (possibly S2 with the latex plus as I hear this makes it suitable for timber) and screwed with 25mm turbo golds. Plan to use 600x600 porcelain tiles although not decided yet.
I’m concerned that by applying a wet adhesive direct to the floorboards will result in them absorbing some of the moisture from the adhesive and swelling/cupping etc.
So my query is:
Is this concern negated by the use of the latex plus instead of water to make it S2?
Should I prime the floorboards first to reduce/stop the porosity? If so what Mapei product?
Also I’m aware the Hardie backer doesn’t need priming/tanking prior to tiling even though it will let water through…all the way to the timber floorboards!. How can i create a waterproof barrier under the tile?
Starting this job this week so appreciate any advice/tips. And I want a belt and braces job not fussed about cost to get it right. Thanks
So my query is:
