Discuss Hardiebacker only screwed to chipboard. No adhesive in the Canada Tile Advice area at TilersForums.com.
L
leothetiler
Hi,
I went to look at a job today, and the homeowner is a keen DIYer. He has been renovating the bathroom. Old tiles removed which were stuck directly on chipboard and hardibacker screwed down. 6mm board over a particularly lumpy floor from the old adhesive, but board not stuck down at all just screwed.
I am worried about the air pockets under the board. The new tiles are large porcelain. Should I tell the homeowner to take up the boards again? Or would the addition of ditra onto the backerboard make it a sound surface to tile? Your advice would be appreciated.
JamesHardie
Hi Leo-
The first step in installing Hardiebacker to the subfloor is to make sure you have a structurally sound subfloor that is not damaged, loose, warped, uneven, and that it has a clean and flat surface. Your concern about the airpockets is a valid one. You must lay the backerboard into a bed of tile adhesive, it is essentially used as that gap filler. Using a bed of adhesive is industry standard when installing a cement board, and we cannot warrant the board without.
I'm including a link to our website where you can download the installation guide as reference, or perhaps it will help you when you go back to the homeowner. JamesHardie | HardieBacker® EZ GRID® 6mm for Floors
Hope this helps!
Mr Tiler
Hi Leo-
Hope this helps!
is it the actual 'air' in that cheeky little pocket underneath the board that is the problem or is it just the fact that there is a void underneath which could result in bouncing movement which will eventually cause the tile/s in that area to come loose? thanks
Mr Tiler
Yes, I would agree with your statement. We call the adhesive layer a gap filling bed of adhesive, and it can be flexible or non-flexible. The purpose isn't to make the board stick, it's to fill the gaps or voids between the subfloor and the backer.
brill mate that's exactly how I think of it. cheers
Rookery
I've always used this method to fix Hardie but have sometimes wondered if, when boarding a perfectly flat chipboard floor, why use adhesive as there are no gaps to fill?
Mr Tiler
in my opinion if a floor is perfectly flat just use a smaller trowel size at least as it surely helps to glue and screw rather than just screw
Herbis
Uk
Sorry to revive a (very) old thread, but I can't seem to find an answer for my question anywhere online - including by contacting James Hardie Support - so hoping you can help?
I have a P5 chipboard floor and 6mm hardie backer to go over it. There are seemingly no options to apply tile adhesive on to the P5 - no manufacturer recommends their product is used in this way, even with primers. How, therefore, is it possible to apply a bed of tile adhesive when going over P5 chipboard? Is it sufficient to use a grab adhesive instead?
Thanks!
Reply to Hardiebacker only screwed to chipboard. No adhesive in the Canada Tile Advice area at TilersForums.com
We just had a 1.5 sq. m area of floor tiled professionally in our ensuite. The base floor is 18...
Hello all, I could do with some advise if anyone would kindly help me. first of all, I’m not a...
Edd The Tiler
E
    Votes: 5 5.0%
    Votes: 8 8.0%
    Votes: 6 6.0%
    Votes: 25 25.0%
    Votes: 14 14.0%
    Votes: 27 27.0%
    Votes: 3 3.0%
    Votes: 2 2.0%
    Votes: 19 19.0%
    Votes: 18 18.0%
    Votes: 10 10.0%
    Votes: 5 5.0%
    Votes: 3 3.0%
    Votes: 1 1.0%
