Discuss Hardiebacker over floorboards in the America Tile Forum / Advice Board area at TilersForums.com.
Herbis
Uk
Hardie used to state that the adhesive under the 6mm hardie didn't have to be flexible as its purpose is as a gap filler. I use flexible as its what I generally have to hand. They have an install guide on there website.
In that case, what’s your view on using gripfill as that’s what I have to hand (…I have a pack of 10 collecting dust)
Herbis
Uk
My view is that the manufacturer doesn't advise using gripfill, it recommends tile adhesive.
Good point, well made. In that case I’ll use tile adhesive. Priming - what do I use for wood? I also have 6mm hardie to go onto brick walls, I intend to use 6mm notched adhesive with 9 fixings per board - can I prime with the same as the floor? Waterproof PVA or other?
Reply to Hardiebacker over floorboards in the America Tile Forum / Advice Board area at TilersForums.com
Seems alot of talk that 20kg per mtr2 is the max weight limit for plaster. Few questions 1. its...
gamer1
USA Tile Forum Popular
America Tile Advice Trending
Uk
What member type are you?
  1. DIY Wall and Floor Tiler
    Votes: 5 4.6%
    Votes: 8 7.3%
    Votes: 6 5.5%
    Votes: 30 27.5%
    Votes: 14 12.8%
    Votes: 28 25.7%
    Votes: 3 2.8%
    Votes: 2 1.8%
    Votes: 19 17.4%
    Votes: 18 16.5%
    Votes: 13 11.9%
    Votes: 5 4.6%
    Votes: 3 2.8%
    Votes: 1 0.9%
