X
xactive
My question is can you use hardiebacker 250 in a wall application, timber stud work at 400 centres, 10mm travertine on top?
The 12mm would bring out the wall too much for the wall mounted taps and fittings so 6mm would be ideal.
I have phoned up the James Hardie tech help and they said there won't be a problem, all the info I have found says 6mm is for the floor and 12mm for walls but I just wanted to check with the pros on this forum who have actually used it rather than the theory of tech support.
Thanks in advance.
Thanks in advance.
