Discuss HardieBoard then level? in the Canada Tile Advice area at TilersForums.com.
I've started tiling my bathroom, floorboards are all screwed down and tight, and i have 6mm hardiebacker to lay first.
but there is a dip from the centreline of the room towards one corner of up to 10mm but mostly 4-6mm. on one side.
do i hardiebacker then level up? or level the floor first then hardiebacker?
and will bal rapid flex one be ok to use to level it up? ( i have spare) or do i need SLC?
Dave
Staff member
Subscribed
389,924
1,000,000
Co.Durham
Thanks, :)
do i need to prime the hardibacker before levelling?
i've got plenty left from priming the walls, but didn't think hardi had to be primed?
It can be primed if dusty or simply wipe over with a damp sponge.
Dave
Staff member
Subscribed
389,924
1,000,000
Co.Durham
Thanks again :cool:
looks like a trip out to get some leveler then, pity as i have a couple of bags of bal rapid flex left over,
but leveler will be easier to lay...
It will yes lol.
Reply to HardieBoard then level? in the Canada Tile Advice area at TilersForums.com
Hi - I ripped up laminate flooring on a concrete subfloor. It was my first DIY project and...
Hi. I've just used Mapei Ultimate Leveller 1210 to cover a very irregular concrete floor in our...
Bedworth
What member type are you?
  1. Contractor
  2. DIY Wall and Floor Tiler
    Votes: 5 5.0%
    Votes: 8 8.0%
    Votes: 6 6.0%
    Votes: 25 25.0%
    Votes: 14 14.0%
    Votes: 27 27.0%
    Votes: 3 3.0%
    Votes: 2 2.0%
    Votes: 19 19.0%
    Votes: 18 18.0%
    Votes: 10 10.0%
    Votes: 5 5.0%
    Votes: 3 3.0%
    Votes: 1 1.0%
