Discuss Hardy Backer board (6mm) OR ply (9mm) for my travertine?? in the British & UK Tiling Forum area at TilersForums.com.
F
ferrisbueller
Hi,
need some advice, as I'm getting a bit of conflicting advice.
I have a half concrete, half floorboard area of approx 46m2. Do I use hardy backer board (6mm) OR ply (9mm) as a base to prevent hairline cracks across the join ??
What do you pro's think?
PS We are using electric underfloor heating, should we use thermal board instead.
PPS we are insulating underneath the floorboards (between joists).
Would welcome some feedback soon as we need to make a decision
PPPS Thanks to Diamontiler for help a while back - we are going with the supplier we talked about - got some good quality for a decent price.:thumbsup:
Rob Z
Ferris, I like the screen name, loved the movie back in the 80's :D .
A movement joint is a "soft joint", designed to absorb movement and stresses in the substrate under the tile. A soft joint can be simply a space that is an unfilled grout line, then filled with a flexible sealant. Or, it can be a product designed for the purpose, such as Schluter Dilex. We have standards here in the US and Canada that we can follow for placement and width of movement joints-Dave or one of the guys here can post a reference for you of what the standards are to follow in the UK. They are fairly easy to follow and to implement.
Some backerboards, such as Wedi Board, are waterproof. Most backer boards are not affected by moisture, but aren't waterproof without a tanking membrane. Generally speaking, backer boards don't add strength to the assembly the way plywood does. If given the choice, I would add plywood for additional strength and then install a membrane to eliminate the potential for problems that might arise from bonding tile directly to plywood.
Reply to Hardy Backer board (6mm) OR ply (9mm) for my travertine?? in the British & UK Tiling Forum area at TilersForums.com
I'm about to tile my kitchen with 600mm x 600mm porcelain tiles. I am tiling onto a subfloor...
Hi everyone. DIYer here looking for some advice. Am tiling a bathroom floor and currently...
Hi, I'm currently prepping my new bathroom for plastering before tiling and am unsure about...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
