Discuss Have read not to tile onto hardwall - what alternatives? in the Canada Tile Advice area at TilersForums.com.
rupert
Hi All,
Re-doing a shower room. All other walls are stud wall's covered with aquapanel.
However the back external facing wall is breeze block with hardwall finish.
The old tiler tiled small format tiles on these 7 years ago and they held up pretty well. However I've been reading around on the forum and people are saying it is not a suitable substrate, even the manufacturer is saying the same.
Now i'm going to be using large format porcelain tiles , 600*300, so skimming the wall is out of the question as I believe the skim will not support these tiles.
So what are the alternatives? Space is tight so I dont want to place aquapanel ontop of the hardwall. Should I take off all the hardwall to the breeze block then mechanically fix aquapanel onto it?
I'd like to avoid rendering the breeze block if possible, as I've seen it crack due to not controlling moisture properly, even when done by a pro. So dont want it cracking after its been tiled and then risk cracking the tiles.
Cheers.
Reply to Have read not to tile onto hardwall - what alternatives? in the Canada Tile Advice area at TilersForums.com
Hi am re tiling kitchen and want some ideas as to what’s best to repair the walls after Remiving...
Hi all - I have some small format ceramic tiles (10x10x1cm) to use as a splash back around the...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
