• Thread starter Ian McGuire
  • Start date
  • Replies 0
  • Views 98
Discuss Heat Exchanger with AGA and heat pump Discussion Thread in the Plumbing Advice area at TilersForums.com.
Hi All I have a client asking whether they can still use the AGA to heat rads once the air source heat pump is in. I think it is possible using a heat exchanger so the low pressure AGA and high pressure heat pump systems don't connect. I've seen it done on biomass systems but wonder what the implications are with heat pump legislation
Heat Exchanger with AGA and heat pump for the original thread on Plumbers Forums
Reply to Heat Exchanger with AGA and heat pump Discussion Thread in the Plumbing Advice area at TilersForums.com
TF Group Please Join
Plumbing Advice
Tags
None
