Discuss Heat resistant adhesive and grout for behind log burner in the Tile Adhesive and Grout Advice area at TilersForums.com.
Dave
Staff member
Subscribed
389,930
1,000,000
Co.Durham
Hi guys
As above , Any recommendations please . I'm tiling onto a freshly cement rendered wall within a fire place ..
thanks .
Dave .....................
If I recall correctly most cement based tile adhesives are ok to around 90 to 100 dgs cels. If higher temps then there are a few heat resistant adhesives on the market.
13
133
UK
Dave is pretty much spot on, cement based adhesives are normally tested up to 150 degrees C. The tiles will normally disperse a lot of the heat so the adhesive never really gets that hot. I've been involved in lots of projects where the tiling is within the fire place and never had any issues. Also make sure the render is at least 3 weeks old before you tile.
Reply to Heat resistant adhesive and grout for behind log burner in the Tile Adhesive and Grout Advice area at TilersForums.com
Hi all, I am planning to tile a full height panel of split face tiles to sit 3” behind a log...
Hi. We've had a bathroom installed with electric mat underfloor heating in a new extension. The...
Tile Adhesive Trending Topics
UK
What member type are you?
  1. DIY Wall and Floor Tiler
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
