Hello and help please with LED strips Discussion ThreadHello and help please with LED strips Electrical Advice
Hello to everyone here,
My name is George and the need to find a solution to my LED strip lights brought me here.
The only knowledge I had regarding LED lights is simply to plug in the usb in a port.
This changed since I ordered from Aliexpress a DC12V WS2815 5050RGB 5m. (5m 144 IP30)
To my ignorance I thought they would come ready for use.
The last couple of days I am searching online, reading and watching many videos in order to understand how to make them work.
The things I have ordered excluding the led strip lights are:
1. Esp32s
2. Breadboard jumper wires
3. 5v power supply.
I have already connected the Esp32s to my laptop, downloaded and installed WLED on the Esp32s.
In addition I have connected the 2 extra wires from the led strip (red and white) to the 5V power supply.
Questions:
1. On AliExpress website although these strips are advertised as 12V and 12V is also mentioned on the strip, as you can see in the photo, the recommended power is 5V
Can I use the 5V I purchased or do I need to buy a 12V power supply? Will they work safely with the 5V?
2. With my limited research I assumed that I could connect one end of the breadboard jumper wires to the esp32 and the other one to the led strips?
I have watched a couple of videos that provide information but the way they connect them is much more complicated than my assumption so I am wondering if what I mentioned above is possible. If not can you please tell me the correct process and also what extra do I need to buy?
3. The led strip has 4 wires (white, green, red and blue) can someone tell me on which port of the Esp32s do the fit?
Thank you
Hello and help please with LED strips for the original thread on Electricians Forums
1. Esp32s
3. 5v power supply.
Questions:
Thank you
