RayJay
Hello my name is Ray
I am a Building Surveyor by profession and also a keen DIY er.
I have recently completed an extension on my house an I am at the floor tiling stage. I have tiled floors previously but not of this size and not with wet underfloor heating.
I have been doing some research on the web including this brillant forum but I am still unclear on some issues and would like some advice.
The floor is concrete screed laid May 2011 by a floorscreed firm including reinforcing fibres ,D49 mesh at stress points (corners etc) .The UFH has been in use since November.
The screed does have a couple of hairline cracks. Part of the floor will exposed to sunshine due to 3 velux windows.
The tiles are 600mm x600mm rectified porcilean.
The floor is L shape, 42m2 with a maximum length of 7.4m.
I intend to leave a 10mm gap around the entire perimmeter.
My questions are:
1.Should I use an isolating membrane over the whole floor or just over the cracked areas ?
2.Should I use 2mm or 3mm spacers?
3.If I need an isolating membrane, I will need a thin one such as PCI pecilastic. I can only find 1 online stockist. None of the local merchants seem to stock it.
Does anyone know of any stockist near Croydon?
I would be grateful for any advice. Thanks.
My questions are:
