JOhnSurrey
Hello and thanks for help - especially 3 way mitre tips - very nice
Anyway, I have a back to the wall WC that will not sit tight ... when it's used I think either:
a) the wc rocks slightly or
b) the power of the flush moves the flange or
c) ... something else ???
Afterwards, a small trickle of water starts to run down out the back of the flange, down the bend and under the front of the wc...
I'm now intending to bed the pan on silicone and use two big screws to hold it in place... the problem is the back of the toilet is not supported so ... it's a weak solution and so far it has not worked...
I'm wondering if the wc spigot is rubbish - it's a little bit oval as opposed to circular and whether this may be causing the flange to be so temperamental
Any input would be greatly appreciated ... I am past the :mad2: stage ...
