• Thread starter CLAYS TILES
  • Start date
  • Replies 8
  • Views 131
  • Tags
    usa
Discuss help,600x600 in the British & UK Tiling Forum area at TilersForums.com.
wetdec
cheers gaz, i'm having a blonde moment wot do you mean by ''plus technology'' ?
:stupid: :stupid: :stupid: :stupid:
Needs to state flexible or suitable for porcelain large format on the bag, that should to it.
No special bits needed but a flat floor is really needed as if you have bumps the tiles because of their size can fly and cause you level problems.
tiler
GazTech
A good majority of our adhesives & grouts already have polymer added to them, so they can stick to porcelain mate....Gaz
BAL PORCELBOND PLUS TECHNOLOGY -
GUARANTEED PERFORMANCE​
BAL Porcelbond Plus adhesives and grouts meet the performance requirements of porcelain tiles by
providing the superior adhesion and flexibility required.
Specially formulated, the Porcelbond Plus range of adhesives and grouts have been developed and​
tested to ensure optimum performance in challenging environments
CLAYS TILES
Darren are these the polished porcelain from b & q by any chance?If so they stain very easily and i contrary to what anyone else says always seal them,you will find out what i mean if it is these tiles,also do you have a cutter big enough for these tiles?What is the substrate you are tiling too?
its on a new build, all rooms downstairs except living room,concrete floor i think!
he told me the size & said its shinny but never said where he got them from!
knowing my luck its the ones you talk about!!:mad2:
CBTC
Make sure the screed is dried through for the correct time...make sure you hoover clean each inch..yes really...dust is your enemy - and prime, and let to dry. Correct adhesive spec. as all others have said, but this is supplied by others so not yr call anyway. Remember just because they are 'big' tiles doesnt mean it all goes down quick and is therefore cheaper...doesnt work that way!
Reply to help,600x600 in the British & UK Tiling Forum area at TilersForums.com
Hi, I'm looking for some advice on the best method to level my ensuite floor. The floor is...
Hi, I have 45m2 of 1.2 x 1.2 Mirage 9mm floor tiles to lay. Never done this size before. I’m...
help,600x600
Tags
usa
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
