Cat
Need to cut 10mm hexagonal porcelain tiles. We have tried using a normal dry cutter on them but couldnt get a clean straight cut.
We then tried wet cutting on our Vitrex Pro 900 but it isnt accurate enough as there is movement along the guide rail which causes the cuts to be between 1 - 5mm out of line
We need a tile cutter that is highly accurate. Ideally a bridge saw as the cuts are all on angles and cant use a fence due to the tile shape. Will also need to be able to handle very slim cuts and L shape cuts
The main problem we had with ours is that we would mark the tile perfectly and then as we pulled the cutter the whole cutter headwould move slightly so the begining of the cut is bang on but the end is out by up to 5mm
Budget is £500ish but happy to spend more if its worth it
Help! Thanks
Help! Thanks
