Discuss Help! Fixing mirror to wall in the UK Tiling Forum area at TilersForums.com.
STEVEROG
I had planned to buy a small mirror to fit above the wash basin in my bathroom. I was going to fix this mirror to the wall using adhesive (aparently there is a specific mirror adhesive). Anyway, the missus purchased the mirror yesterday and it has four fixing holes, one in each corner. Now, I am not sure exacly how I should go about fixing this miror to the wall apart from the obvious fact that I need to screw it to the wall. My concern is that unless the wall is absolutely flat then as I wind the screws in the mirror could try to flex and then crack. Another way I suppose the mirror might be damaged is if the screws don't stay exactly central in the holes through the mirror and end up cracking the mirror again. I am thinking that I need some form of rubber spacers behind the mirror to allow for variations in the wall and some form of rubber washer between the edge of the hole through the mirror and the edge of the screws. Any ideas?
Help!
diamondtiling
Hi steve,
if the mirror did not come with a fixing kit then you can buy one from b & q,
if you drill it correctly then you should not have any problems, it was manufactured to take 4 screws to hold it, all mirrors flex a little, you could buy some mirror adhesive and give it extra support if you want, again b&q stock this item, its about £8.00 a tube,
goodluck
:thumbsup::thumbsup:
Reply to Help! Fixing mirror to wall in the UK Tiling Forum area at TilersForums.com
Hi all, I am in the middle of renovating my bathroom. First of its kind for me! The walls were...
  • Sticky
I need help on what prep I need to do. I have read on the forums here and I seem to be going...
Hi All. I'm installing a new shower enclosure and hoping for some advice on fixing the 12.5mm...
6K
hmtiling
H
    Votes: 9 6.3%
    Votes: 13 9.0%
    Votes: 9 6.3%
    Votes: 44 30.6%
    Votes: 17 11.8%
    Votes: 34 23.6%
    Votes: 3 2.1%
    Votes: 20 13.9%
    Votes: 18 12.5%
    Votes: 15 10.4%
    Votes: 7 4.9%
    Votes: 3 2.1%
    Votes: 4 2.8%
