Dunnster
Having read loads of excellent threads, I am kitted up and ready to start on the dining room. Just have a couple of questions for the experts if you would be so kind? First the background...
12 sqm dining room, floating chipboard floor and the skirting boards are staying down (she has decided). I am boarding out using 12mm exterior marine ply, screwed at 200mm centres with 4x25mm chipboard screws. Then sealing with pva/water and using Unibond flexible ready-mixed adhesive & grout.
First question - should I leave expansion gaps at the edges and/or between sheets of ply?
Second question - I intend to silicone around the edges against the skirting board. Should I grout first and run a bead over, or just use silicone in the perimiter gap?
Hoping to get the ply done this weekend, any help would be appreciated. I will take some pics of the stages to post if it would be of interest to anyone.
Ta, Dunnster
Ta, Dunnster
