Discuss Help! Hollow loose floor tiles in the Best Floor Tiles area at TilersForums.com.
tiger11
Four months ago I tiled my kitchen floor with large floor tiles some of which now sound a bit hollow and others are starting to move a bit.
Background: Firstly I screeded the concrete kitchen floor to level it after removing old tiles. When the screed had dried it was sealed with PVA. The tiles were laid on top of Wickes ready mixed floor tile adhesive for concrete floors. I replaced two of the tiles in January because they had started to move a little bit and the grout between the tiles was cracking. When I had taken these tiles out the floor sounded hollow when I knocked on top of the screed bed. Now some more of the tiles are sounding hollow and the grout around them is cracking a little bit.
Does anyone have any ideas why this is happening?
Alan.P
If the screed is sounding hollow where you have lifted tiles it sounds like a failure to bond between the screed and concrete floor below it, you say that the adhesive has bonded to the screed completely, but only partially onto the tile, if you look on the back of the tile and also the space it came out of, what amount of coverage was there, how much tile was touching adhesive ?
Also, was the screed lifted with the tile when taking them up ?
Alan.P
The adhesive had completely bonded to the screed. No screed lifted at all from the concrete floor. The back of the tile had about two thirds adhesive sticking to it. The rest of the tile was clear of any adhesive.
In that case sounds like 2 things haven't happened, the screed hasn't bonded to the concrete ( was it primed / devoid of dust etc ) and a 'simple' coverage problem whilst fixing the tiles, maybe a level problem ?
tiger11
There weren't any problems with the level at all. The screed is stuck fast to the concrete with no loss of adhesion even when lifting the tiles. Any ideas as to why parts of the tiles themselves are not sticking to the adhesive as the missus has pointed out that other tiles sound a bit hollow now, especially in areas of foot traffic. Can anything be done? I don't really want to have to lift the whole floor.
Thanks again.
DHTiling
With it bieng a ready mixed adhesive then it might have skinned before you had time to lay the tiles....Not sufficent adhesion to the tile...
Without seeing it , i would say it will probably be a re-tile but use bagged adhesive that you mix and not tubbed gear...but as we cannot see the extent or how much is loose or is going to come loose then the call is yours i'm afraid..:thumbsup:
U
Unregistered
I had the same problem with loose tiles in my kitchen, There is a product I used called FixaFloor which is specifically for this problem. You drill holes in the grout around the tile then fill the void with the special Fix a Floor bonding solution which solidifies over 24 hours. once done you just put a little bit of grout into the holes you drilled and no one will ever see that you did anything to your floor!! It solved my problem and now my Kitchen tiles don't move any more! : ) Have a look at the videos on http://www.fixafloor.co.uk they show you how this works
Reply to Help! Hollow loose floor tiles in the Best Floor Tiles area at TilersForums.com
Hi everyone, I'm not a regular tiler, just someone who is trying to fix up a few rooms around...
Best Floor Tiles
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
