Discuss Help leveling floor slc? in the British & UK Tiling Forum area at TilersForums.com.
H
Hayden Goy
Hi all,
I have a dip of around 10mm in the corner of the room. I have wpd ply floor and have purchased some underfloor heating insulation but do I lay some slc to level the floor or build it up with tile adesive when I tile?
If slc what the best ?
So just to recap-
concrete floor with glued ply on top
then I want the u/f insulation
then tiles.
What should I do??
H
Hayden Goy
If i were you m8 i'd rip up the ply, level the floor, fit your insulation boards then level again (just up to height of cables) then you have a good surface to work to. Why was there ply glued to the concrete base?
Cannot take the floor up fitted kitchen in. It was put down as I was told I could use wbp ply for flooring then prime them u/f/h then tile. It's glued down with everything. Taking it up is not a opion
Reply to Help leveling floor slc? in the British & UK Tiling Forum area at TilersForums.com
Hi, I'm looking for some advice on the best method to level my ensuite floor. The floor is...
Hi all, Was looking for some advice in regards to micro-cracks appearing on the SLC on top of...
Hi, Soon to lay 500mm sq tiles onto screeded hall/kitchen floor 25m2. Hall floor has vinyl...
    Votes: 9 5.6%
    Votes: 17 10.6%
    Votes: 11 6.8%
    Votes: 44 27.3%
    Votes: 21 13.0%
    Votes: 38 23.6%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.7%
    Votes: 19 11.8%
    Votes: 17 10.6%
    Votes: 8 5.0%
    Votes: 5 3.1%
