bazza999
Hi all,
Needed some help..... there is a bit of sag in the centre joists (see pic). Gap is about 1cm at highest point. Whats the best solution? Is there a substanc whiadheres to wood and solidifies, providing a solid base?. I was thinking something along the lines of no-nails type adhesive or something which I can spread on the affected joists, lower the tray in to place, and let the tray bed itself, then screw the tray down. Or is it a case of getting 10mm piece of stick and sliding it under....
Any ideas? I have the no-more-ply adhesive that will be used to stick the tray down too, will that do the trick?
any help / ideas would be greatly appreciated
thanks in advance.
thanks in advance.
