Jimmy Boy
Question :
I'm halfway up around a four walled bathroom, or five walls (including an external corner) as one wall has a box wall covering water/waste pipes etc. Top of all tiles are spot on level.
I have a datum line I marked around all walls above the door frame (the only area where all walls meet) I used a 1.2m level and marked the line that meets perfect.
I have taken measurements from this datum line to the top level of tiles at different points and have found a discrepancy in measurements of 3mm yet everything is registering as level.
I intend to finish above the bathroom door but my concern is the grout lines meeting, how do you guys make adjustments when you are approaching that point to make sure your grout lines meet spot on?
Edit* I have a 2mm grout line and tiles are being fixed brick bond.
Thanx Jimbo
Thanx Jimbo
