Discuss Help needed with Bathroom Tiling in the Bathroom Tiling Advice area at TilersForums.com.
chris316
Hi
This is my first post on here, so please be gentle, and bear with me.
I am for tiling my bathroom, walls and floor. And I have a few questions which I would be very greatful if someone could answer, or give me some advice.
My bathroom has plastered walls which had been painted with emulsion paint. Originally I was going to just key the walls and tile over. But when I keyed the walls the paint came away in places so I decided to remove the paint from all the walls, right back to the plaster.
My questions are:
1. After removing the paint from the walls you can still see where the
walls have been keyed/scored right back to the blockwork/undercoat
plaster. Can I tile the bare plaster walls with the key marks, or will the
key marks have to be filled up prior to tiling?
2. Do the plaster walls still need to be keyed/scored now that the paint has been removed?
3. When removing the emulsion paint and keying the walls there are small
areas of the wall where the finish plaster was very thin and has come
away. What would be the best filler to use to patch the
walls up, or would I need to re-skim the walls?
4. Do I need to prime the plaster walls prior to tiling. If so what would be
the best primer to use?
5. I have also had to re-plaster a bit of the wall where I installed a new
shower. Can I tile on top of this new strip of plaster straight away?
or do I need to leave it to dry properly, and if so how long do I need
to leave it?
6. Finally, I also plan on fitting a new plywood floor, does this need to be
primed and if so, again what would be the best primer to use?
Sorry if my questions are a bit long winded.
Chris
diamondtiling
Prime all the surfaces with an acrylic bond.
What adhesives are you going to be using?
Ply is fine on the floor, 18mm minimum, bond the reverse side before fixing and add plenty of strength to the joists, I fix 6mm backer boards over ply for a better tiling surface.
Welcome to the forum by the way.
:thumbsup:
Scott
:welcome:
How thick was the new plaster? Rule of thumb is leave it 1mm per day to dry, however with the milder weather we are having now that should speed things up. With the skim plaster thats come away, you can make that up with adhesive if its only thin. Would have to be a cementious adhesive though.
chris316
Hi
Thanks for all your replies so far.
faithhealer - With the finish plaster coming away and exposing the bare blockwork, undercoat plaster, I was a bit worried about the tile adhesive not setting right at these places as i was told by someone not to tile directly onto undercoat plaster. Just so that I know for the future, if I have bare plaster walls, do they have to be keyed/scored before tiling or is it only painted walls which need keyed/scored?
Diamondtiling - I will get back to you later regarding what adhesives I will be using. I don't know exactly, because when I bought the tiles from the tile shop, they gave me all the adhesives, grout etc that they said that I would need.
Scottley - There is some large areas where I had to replaster. I tracked the wall to install a new pipe and cable to a new electric shower this will need to be plastered. Also when I removed the couple of old tiles at the window, half the window sill came away, and the other half I had to remove because it was hollow underneath, This is because the previous owner of the house installed new wooden framed double glazing and made a terrible job in fixing the wall. By the way would you know if I need to prime the existing plaster walls before re-plastering these areas in order for the new plaster to take correctly?
Can you tile on walls fixed with Polyfilla? Its just that I have some holes in the wall to fix which I was going to fix with Polyfilla or is there a better wall filler to use?
Scott
Hi
For replastering yes, prime them and as for polyfiller, if you have plaster why not use that? :thumbsup:
chris316
Tileshop has given me the following:
Adhesive for wall tiles - Larsen's Professional Showerproof high grab, non-slip, ready-mixed, thin-bed adhesive
(Larsen Building Products - Tiling - Manufacturer, Supplier of Concrete, Mortar and Plaster, Tiling, Flooring, Waterproofing, Timber and Filling and Sealing products based in Northern Ireland.)
Adhesive for Floor tiles - Larsen's Professional Flexible Fast Set
And also some BAL tile grout.
I'm now beginning to wonder wether or not the adhesive they have given me for the floor tiles is suitable. Because my bathroom is upstairs and the floor tiles are going on a wooden floor which I will be sheeting with new plywood.
chris316
you need to take the tubbed addy back, they should never have sold it to you for that size of tile
pick up a cement based addy
weather you prime the ply will depend on what larson recomend but you will need to prime the plaster walls
Whats wrong with the tubbed addy they sold me?
Reply to Help needed with Bathroom Tiling in the Bathroom Tiling Advice area at TilersForums.com
Hi, can anyone advise me on how to prep a painted brick or block wall for tiling? Do I just wash...
Hi all am changing tiles in my kitchen ans expect to damage the walls removing tiles . Think the...
Unsolved
    Votes: 13 8.8%
    Votes: 11 7.5%
    Votes: 44 29.9%
    Votes: 17 11.6%
    Votes: 35 23.8%
    Votes: 20 13.6%
    Votes: 15 10.2%
    Votes: 7 4.8%
