Discuss Help on Setting Out in the Canada Tile Advice area at TilersForums.com.
Hi there, this is my first post and looking for advice on fixing 550x330x8mm ceramic wall tiles to two bathroom walls. I have started the short wall in the shower enclosure and seems to have gone ok. Have just set the first tile to continue around the corner to cover the longer wall (3metres). Looking at the edge of this tile I have a total thickness including tile of about 13mm. Is this ok for bed thickness? The walls are plasterboard and have had two coats of tile primer. As these are larger tiles, I am using levelling wedges as well as 3mm spacers. Any tips would be appeciated, Thanks.
Reply to Help on Setting Out in the Canada Tile Advice area at TilersForums.com
Hi, 1200 wide tray and tiling shower enclosure recess with metro tiles where the 1200 wide...
Hello, I am looking for some advice on how to set out my tiles. I think I have a solution but...
Suffolk
What member type are you?
  1. DIY Wall and Floor Tiler
Help on Setting Out
    Votes: 9 6.3%
    Votes: 13 9.0%
    Votes: 9 6.3%
    Votes: 44 30.6%
    Votes: 17 11.8%
    Votes: 34 23.6%
    Votes: 3 2.1%
    Votes: 20 13.9%
    Votes: 18 12.5%
    Votes: 15 10.4%
    Votes: 7 4.9%
    Votes: 3 2.1%
    Votes: 4 2.8%
