N
nelly123
Pic attached.
I have built a water feature from concrete block and skim rendered them to seal. I used swimming pool tile adhesive to fix the slate tiles (8" by 18"). Some have water running over them slightly but the rest are on the outside of the feature. My problem is that the slate tiles keep falling away. I have tried to score the slates with a dremel drill to help them stick but they still fall away after a while. I have used black grout may be this would be better if I use black silicone to allow expansion. Can anyone recommend a way of doing this without the tiles falling away after a few months. I really like the feature and think that the tiles make it look good so really don't want to use anything else. The tile adhesive is not sticking to the tile, but is sticking to wall. Would painting the tile with something like pva allowing to dry and then fix work???? Any help welcome. Is there a way of fixing tiles on a runner or grip that fixes to the wall???? SOS.......
