E
ern
Hello all, I need your advice again.
Got to put porcelane mosaics down on an aqua dec indoors, however the rest of the floor is going to be 40 x 40 porcelane tiles. Basically both tiles are the same but on is a 30 x30 mosaic sheet and the others are 40 x 40.
For the large tiles I was going to use a 1/2 inch U notch trowel and for the mosaics a 6 mm square notched. both tiles are the same thickness, 10 mm. Would this be correct. I want to ensure they all end up the same level.
Also, in the aqua dec, is there a particular way to finish around the hole before puting the grate on. WOuld appreciate any help.
THanks all, Ern.
THanks all, Ern.
