Discuss Help please - Have I ruined the job?? in the British & UK Tiling Forum area at TilersForums.com.
mick7
Grouting the tiled floor - a total nightmare,
60 x 60 polished beige porcelaine - 5sq metre - beige Mapei ultraplus.
Had an absolute nightmare grouting!
All tiles laid lovely and level and looked good. I thought the tiles were clean I even hooved them
However I had obviously got some tiny bits of adhesive(grey) left on the sides of the tiles and they have come through on the grout. The grout is uneven, went all over the place using the rubber trowel and there was obviously too much water on the sponge when I've tried to get it up!
Can I rake it out and re-grout. How do I get rid of the grey bits. A total nightmare. Finished 30 mins ago and thought I'd make a cry for help please.
DHTiling
Any adhesive that's showing just rake it out with a scraper or utility knife.....take your time and make sure you get it all....then just re-grout these bits and touch in the other unlevel bits before it dries to much or it won't key to it.....make sure you rinse sponges etc out well and lightly wipe the joints don't press on to much....
White Room
Before I grout allways check joints for any adhesive that may have stuck to edge of tiles, For any light grout I use a white addy. I'd regrout asap before sets hard and use a stanley knife on the edge of the tiles to scrape any grey away or fein multimaster if you have one to get bulk of grout out, or plenty of elbow grease all the best.
DevonChris
Hi mick,
Don't worry! Go through and take out all the visible adhesive.
If the grout is patchy coloured or uneven in levels take the surface off all of it.
Best to use a manual grout raker. They work really well and either buy a couple or 1 plus a spare blade. You may need a knife also but be careful not to slip and scratch the tiles. You can get them from a local tile shop.
I once went to a job where someone had left ultracolor on for hours before trying to wipe it off and ruined 100m2 of expensive tiles! I'm sure he felt worse than you when the whole site were washing the floor with brick acid!!
When you regrout, take the worst off first before your finishing wipe and use warm/hot clean water. I've found that's the quickest way to use ultracolour and leave a good finish.
Let us know how it goes!
Chris
brian c
mick did you seal the tiles before you grouted,if not try this aswell as the above.Ifind that if i seal them then i dont have any problems like you have bud,worth a try but i know not everyone seals polished porcelain as trhey think it dont need sealing but i beg to differ,we had a thread about this two weeks ago,check it out.
Dan
Admin
Staff member
5,100
1,323
Staffordshire, UK
best thing to do is wash off as you go. ;)
With some of the grout sinking you may have just filled some of the voids under the floor - if there are voids you may find the tiles aren't as tough if you drop things on them (even thick stone if you get it right) so 'sound' the tiles (tap them with a coin and spot the hollow bits) if it is you have an area with a few hollow sounding tiles then maybe before you re-grout you repair that?
I may be barking up the wrong tree so to speak - really depends on how 'uneven' the grout is - and if you mean some has sunk.
mick7
nightmare with grout
Hi All
Well I've looked at my job this morning. Not very happy but maybe someone can give a bit more advice.
The main problem now is the uneven colour of the grout. It looked fine last night.
Its smooth and level enough, probably not to your standards but I could'nt do anymore last night. The colour is supposed to be Mapei Beige, but it varies from beige to nearly white over the whole floor. No one gout line seems the same colour throughout.
It was absolutely fine in the bucket and looked a uniform colour
What can I do?
mick7
Thanks for that. Yes light is equal everywhere.
I have just discovered that apparently this is a problem with Mapei Ultraplus due to the crystallised polymers not being equally distributed in the bag ! Great. You apparently need to shake the bag before use, and if you are using only part of a bag its even more of a problem . Bit too late for me. Very very angry.
Spoke to Mapei who are sending me Fugha Fresher ( beige goute paint) to try and rectify the job.
Think i'm going to have to rake out the whole floor and start again.
Reply to Help please - Have I ruined the job?? in the British & UK Tiling Forum area at TilersForums.com
Hello! At the completion of my new kitchen tile installation, the grout I had selected (dark...
Can I ask advice please; I have MS and the worry is making me ill. The tiles are all chipped...
Hello all! I don't usually use forums so bear with me. I've tiled my downstairs toilet, I...
Please can someone who knows what they are talking about help me out. I am very unhappy. I...
2 3
8K
I just had some tiles put into my small WC and the tiles are uneven, poorly cut, unevenly...
10K
Deleted member 52073
    Votes: 9 5.4%
    Votes: 17 10.1%
    Votes: 12 7.1%
    Votes: 47 28.0%
    Votes: 21 12.5%
    Votes: 40 23.8%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 23 13.7%
    Votes: 19 11.3%
    Votes: 17 10.1%
    Votes: 8 4.8%
    Votes: 5 3.0%
