Discuss Help required in the Australia Tiling Forum area at TilersForums.com.
charlie1
I've been asked to price for replacing a few of these tiles, they have spare tiles but will need cleaned up. 2 questions, can anyone recommend a supplier and 2, grout! It's like a resin grout 1-2mm thick... Can anyone shed any light on this type of grout joint. Thanks
L
lizzardtong
http://m.youtube.com/watch?v=UsxN9jJJiog
Found that as well:
just browsing some old posts and found this one of interest.
As a norm of rule terrazzo should only be grouted with cement.
the epoxy resin is only a quick patch repair and should only be used for a temporary repair. There are a few areas where a site ask for any tiles to be laid and resin filled on the same shift, as to keep a low disruption to there stores.:ban:
When grouting terrazzo these tiles should be flood grouted as to allow the tile and grout become 1 so as the grout will grab the tile and hold in one place.
If you use resin (and trust me i have been on a lot of sites and repaired other tile replacements where sub contractors resin fill). when doing this the resin will not completely fill joints and usually only fill 8mm of a joint (remembering a tile is 23mm thick.) then they will grind off and polish a tile this will generate heat and soften the resin ,once the resin has cooled down the resin will shrink and leave a small hair line crack.
Always cement grout and leave for 4 / 5 days before polishing....
http://www.tilersforums.com/tile-adhesive-grout/9280-does-anyone-know-what-terrazzo-grouted.html
Reply to Help required in the Australia Tiling Forum area at TilersForums.com
Hi everyone. I'm really hoping you all can help as I am at my wits end. We have hired...
Hello! At the completion of my new kitchen tile installation, the grout I had selected (dark...
Help required
    Votes: 9 6.3%
    Votes: 13 9.0%
    Votes: 9 6.3%
    Votes: 44 30.6%
    Votes: 17 11.8%
    Votes: 34 23.6%
    Votes: 3 2.1%
    Votes: 20 13.9%
    Votes: 18 12.5%
    Votes: 15 10.4%
    Votes: 7 4.9%
    Votes: 3 2.1%
    Votes: 4 2.8%
