Discuss Help! Split face stone tiles on a ‘dry lined’ wall in the Canada Tile Advice area at TilersForums.com.
Hi guys,
Long time lurker, first time poster etc I hope someone can give me some pointers please
I am doing up the living room and my other half has her heart set on 2 sq metres of split face stone on the wall (I’ve attached an image of her dream!)
The wall is a dry lined wall that’s currently painted (I’ve attached an image of the room as it is, red squiggle shows the areas to be tiled)
What is the best method to attack the job?
Tile straight into the current wall
Or screw something different through into the breeze blocks behind the plasterboard
(Cement boards or ply wood?)
Any help or ideas would be very helpful!
James
I read it that you want to tile straight on the walls so a cement board over the walls in question, screwed into the block. Screws countersink quite well into Hardiebacker if they’re the fluted type
Observe the permissible cable runs from the sockets though.
Thank you all, Waluigi’s idea might be the one that works...
We aren’t studding the bit to be tiled, just the framework for the TV and the electrics.
We are getting tight in depth with the door on the right hand side. We would get away with screwing 6mm cement boards through the existing dry lined wall into the brickwork, then adhesive and tiles on top. Any more depth and the door wouldn’t open!
Waluigi, am I interpreting correctly that this would be your idea? Multiple screws through a 6mm cement board to secure to the brick behind?
Would ply be a workable option? The walls aren’t 100% perfect (new build house!) and I’m concerned the cement board may crack in tightly fixed against a surface that’s not totally flat
Thank you all for your help so far!
Reply to Help! Split face stone tiles on a ‘dry lined’ wall in the Canada Tile Advice area at TilersForums.com
Hi all, I am planning to tile a full height panel of split face tiles to sit 3” behind a log...
Hey everyone! Just want to say first of all that I am not a tiler or anything I’m just in need...
Hi there, I'm in need of advice for how to remove split face stone tiles. As there's no grout...
Hi all I am thinking of getting a Mediawall built with split face tiles on each side. Very...
Southampton
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
