Discuss help- tile adhesive not drying properly??? in the UK Tiling Forum area at TilersForums.com.
omie_1_kenobi
Hi I need some advise. I am retiling around my bath and it is going well, but taking a long time because trying to look after a toddler and baby at the same time. I am using Bal white star on 25x33cm tiles and it looks good. I'm almost finished and the tiles stay up and when I try to move them they won't budge, BUT I had to take some off because I wanted to change something. I put a screwdriver behind and pulled it off quite easily. The adhesive still felt a little damp. We have been having baths and my husband did steam the bathroom up the other night. Is this a problem or will the tiles be fine and I should stop worrying and grout them in? Really worrying because already spent loads on all the Bal adhesive and grout. They have been done bath to ceiling for nearly a week now and no sign of moving. My plan is no more baths until the last tiles are up, had 3 or 4 days to dry and the grout is on and dry. Any advise very welcome!!!
DHTiling
Hi, no need to prime with a tubbed dispersion adhesive, this will hinder the dispersion process of the adhesive and slow down the setting time.
Also if you are using it above the recommended thickness (3mm) then this will also increase setting time and will also create an issue with structural strength to the adhesive bed.
Reply to help- tile adhesive not drying properly??? in the UK Tiling Forum area at TilersForums.com
Been advised to move this post to the uk forum, didn’t realise it was in the USA forum Would...
    Votes: 5 4.0%
    Votes: 11 8.7%
    Votes: 8 6.3%
    Votes: 36 28.6%
    Votes: 16 12.7%
    Votes: 31 24.6%
    Votes: 3 2.4%
    Votes: 2 1.6%
    Votes: 19 15.1%
    Votes: 18 14.3%
    Votes: 14 11.1%
    Votes: 6 4.8%
    Votes: 3 2.4%
    Votes: 2 1.6%
