Discuss Help: tile size for 800x800 shower enclosure in the British & UK Tiling Forum area at TilersForums.com.
ceet
Dear All
Hope someone can help! Tiling 800x800 shower enclosure, have purchased the following Bal items for the tiler following advice available here:
  • single part flexible adhesive
  • waterproofing kit
  • microflex grout
  • sealant
The walls have been replastered by plasterer but house is mega old, so walls still not quite flush!
Would love to get largish tiles but, as I understand it, for such walls smaller tiles are best, so I've bought 20x20cms.
My questions are:
  • would a bigger tile be feasible with such a slightly uneven wall and, if so, what is the likely maximum size tile size that I could get away with; and,
  • is this 20x20 tile size inadvisable?
Know this is a diffiicult one to call without actually seeing the wall in question, but would appreciate any words of advice you still might have!
Many thanks
Ceet
ceet
If you had larger tiles you could lose the shape of the wall, smaller tile you will have to follow the shape of the wall.
If you do change your tiles keep them to ceramic for the weight issues on the wall.
Many thanks, Whitebeam, for getting back so quickly: do you mean that I could indeed use a larger tile inspite of the uneven wall?
Had heard that if wall uneven then was restricted to smaller size? Confused!
ceet
Depending how uneven, larger tiles can be bedded out with addy to bring the wall quite level, smaller tiles would need a flatter wall to look good
Cheers, Whitebeam: guess I'm wondering whether or not 20x20 size is usually considered fine for shower area given increased grout area?
Reply to Help: tile size for 800x800 shower enclosure in the British & UK Tiling Forum area at TilersForums.com
Hi, 1200 wide tray and tiling shower enclosure recess with metro tiles where the 1200 wide...
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
