smac74
Hi, the arguments about tiling the floor before the walls, when using the same tile and your lining the joints up ?
The floors about 5sqm, walls 25sqm 60x30cm porcelain. I would normally always lay the floor first in this scenario, as you guarantee matching the joints on both wall and floor. I know if they don't need to line up, walls can go up first and if the rooms small enough you can set lines out.
The boss of the plumbing firm I was doing the job said he'd never come across anyone doing it that way before, personally I was amazed, which way round do other tilers do it ?
Surely it's not that uncommon, is it !
steve
steve
