williams
Ok hello to everyone, first visit here and a good site but theres so much info i,m a bit lost.
This is a DIY project, i have my own paving company so i would hope that tiling is second nature :drool5: i have laid many different types of stone from proper granite setts to 25mm thick granite strips, i can turn my hand BUT the job has to look perfect so i,m here to ask a few questions i am stuck on.
first the floor
i want to lay 600x400 travertine in strecther at 45 degrees, existing sub floor is concrete screed, i am not sure on the quality of the floor? - should i pour some leveling screed over it to take any dips away? if so what?
what adhesive- just any flexible white?
seal tiles first? again whats the stuff to use?
grout with what?
seal after installation?
The walls:
just want to do something like 200x100 in strecher, will be approx 400mm high around worktops. walls are plaster on the crappest render you have ever seen, i only just moved in and have been ripping the loose plaster off all week, it all seems sound now and am having the damaged stuff skimmed. Existing tiles were a 100x100 ceramic and were fine (until i started scraping off the plaster :incazzato: )
So anything else i should know?
first the floor
grout with what?
The walls:
