BigAl
Hi, I'm about to start on my bathroom and need a bit of advice regarding current state of the walls. As you can see from the pictures, the old tiles were tiled onto plaster and removing them has pulled a lot of the plaster with them, leaving the render beneath showing.
I was wondering if it would be ok to chip off as much of the old plaster that's left (the loose stuff), then tile onto the render? Would I need to prime the render first? Many thanks.
