help with wet room
V
velvetsmile
Hi
I am new to forums and only been tiling for a year so not a veteran. I have a bathroom conversion to do and the gentleman I am working for has bought a wetroom base or tray himself from tilux Germany. It looks really easy and the waste fits into it not like others I have seen but is not made of fiberglass. Does anyone know anything about this base will it be ok as I dont want to make a mistake?
Vsmile
not too sure myself but im sure someone will get back to you tonight so check back then.
very straight forward to fit velvet, just make sure it s level and away you go,
Hi
Someone found me a link for the tilux site (english) I studdied it last night and its now in with the waterproofing all done. It was quite easy with the instructions off the tilux website you gave me. The waterproofing is done with a membrane and was easy i just rolled it out onto the adhesive. The drain locked into place with sealing rings and I would use one again so will contact the tilux site for the costs if it can be bought over here that is.
Again thank you for the help
V
help with wet room
velvetsmile,
velvetsmile,
velvetsmile,
velvetsmile,
