Discuss Hexagon tile cutting in the Canada Tile Advice area at TilersForums.com.
Hi Guys,
I’ve have a job coming up to install lily pad porcelain hexagon tiles.
It’s the first time fixing hexagon tiles, it’s straight forward just one wall 2.3m x 0.9m.
My question is this, when it comes to cutting the tiles is it only really possible with a wet cutter or grinder due to the tile shape?
I’m just thinking for example cutting through the top and bottom points, then snapping on a manual cutter won’t work?
Any help/tips appreciated.
Cheers.
andyb1
453
Bedfordshire
Hi Guys,
Cheers.
Depends what manual cutter you have, i use a Rubi tx to cut them, no problem.
Reply to Hexagon tile cutting in the Canada Tile Advice area at TilersForums.com
Advice Hi guys, got some 60cmx60cm porcelain tiles to lay in a hallway with a modular pattern...
Hi all. Just after a quick bit of advice. The other half wants porcelain slabs for the patio...
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent...
Hello, I hope you can help. I'm get despondent cutting 9mm glazed porcelain tiles, 300 x 900mm...
Bristol
What member type are you?
  1. Professional Wall and Floor Tiler
Business Name
Trym Ceramics
    Votes: 5 5.0%
    Votes: 8 8.0%
    Votes: 6 6.0%
    Votes: 25 25.0%
    Votes: 14 14.0%
    Votes: 27 27.0%
    Votes: 3 3.0%
    Votes: 2 2.0%
    Votes: 19 19.0%
    Votes: 18 18.0%
    Votes: 10 10.0%
    Votes: 5 5.0%
    Votes: 3 3.0%
    Votes: 1 1.0%
