Stanman
Hi all,
3 months ago we started a full house renovation that has consumed almost every working hour. Amongst the work, is a full refurb of our bathroom. I've never tiled or done any significant DIY before so this is quite a good learning process. I'm keen to learn new skills and welcome any advice and tips from more learned members here.
so far I've built a stud wall in the bathroom and managed to marmox board the floor and fit a shower lay for level access. Also managed to clad the stud wall with marmox. Sadly the remaining plaster walls are significantly bowed out. I've dot and dabbed 10mm board and fixed in 12 points for security and merged these with 20mm board to keep things level.
My my mosaic wall is also bowed due to bad plastering and I'm wondering if I should dot and dab over again to level OR Chop back to block work then fix. The walls are the crumbly thermalise stuff that doesn't hold up too well to a SDS chisel. They are also painted and papered over.
I'm wondering how to proceed from here. I'll post some pics when I get home to help clarify things
stan
stan
