DDD
Hello, been reading for a while and getting lots of helpful advice. Especially when the builders were going to put 6mm ply on top of osb for tiling the floor!
We are having an extension built, meaning 2 new bathooms. I'm an experienced DIYer, done a couple of bathrooms in the past but basically made do with existing structure. This time having a blank canvas, trying to do everything correct. Already posted a question about screws for the marmox boards as was quite eager to start ordering everything I need.
This is what I have planned. Two bathrooms, main and ensuite.
Both have mix of block and stud wall, suspended timber floor (3 foot crawl space underneath). Ensuite will be a wet room.
12.5mm Marmox boards on walls and floor (might reduce down to 10mm for the floor). Floor has 18mm WBP, well screwed down/supported.
Fixing Marmox with adhesive (Mapei Keraquick) and screws/metal washers. UFH (Devi-mat), SLC (haven't chosen which one yet), then tile (300x450 porcelain on wall, 300x300 floor. (Mapei keraflex maxi for walls to give me a bit more working time).
Ensuite - using marmox showerlay, marmox boards, waterproof tape, Devi-mat/SLC, then similar tiles with matching 5cm mosiacs for showertray.
Currently deciding between Ardex or Mapei grout, plus whether any additional tanking is needed.
Is that everything, never done quite so much preparation before, but wanting this to be a good job.
