Discuss Horstmann H425 Timer Replaced with E7+ but not working Electrical Advice in the Electrical Advice area at TilersForums.com.
Horstmann H425 Timer Replaced with E7+ but not working Discussion ThreadHorstmann H425 Timer Replaced with E7+ but not working Electrical Advice
I have a Gledhill Pulsacoil III cylinder. Recently the Horstmann H425 timer stopped working and I hired an electrican I know well to replace it with a modern Secure Horstmann Electronic E7+ Hot Water Programmer (Gledhill confirmed this timer is compatible). He says he connected it up the same way as the previous old timer H425, which worked fine before the mechanism failed.
However I think he must have got something wrong, as the boost element works fine on the timer but the economy 7 element is not working at all. I can see this from the app. Both elements have been tested with a multimeter and are reading about 17-18 Ohms so they're ok (or at least either should both be working or failing). I have coloured the wires in thew photo to show how it's wired up.
Does anyone have any idea of what's wrong or a recommendation of someone around London very familiar with these timers who could likely repair it?
[ElectriciansForums.net] Horstmann H425 Timer Replaced with E7+ but not working
Horstmann H425 Timer Replaced with E7+ but not working for the original thread on Electricians Forums
Reply to Horstmann H425 Timer Replaced with E7+ but not working Electrical Advice in the Electrical Advice area at TilersForums.com
Lou
Staff member
Admin
Staffordshire
Website
https://www.TilersForums.com
What member type are you?
Business Name
TilersForums.com
Electrical Advice
Tags
None
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
